Oops! 😊
Got som sand in the top keypad (yes/no, menu, c etc). Still working, but not the same :P How do I remove it, anyone?
Oops! 😊
Ungjaevel wrote:Oops! 😊Got som sand in the top keypad (yes/no, menu, c etc). Still working, but not the same :P How do I remove it, anyone?
Do a search in the forum, there is a post that shows you how to take the N80 apart, you should be able to clean it that way
Cash wrote:Do a search in the forum, there is a post that shows you how to take the N80 apart, you should be able to clean it that way
http://www.allaboutsymbian.com/forum//forum/thread/47020/&highlight=remove+cover
cheers
Dx
