i have downloaded some softs from various sites. Then i copied files *.jad, *.sisx to my midi SD card. I run them on my handphone and the applications were saved on the card. After using 1 week without no problem, i use McAFee to scan my card and i discover that my card is infected by virus W32/Rontokbro.gen@MM.
I dont know whether my phone is infected or not?
Can someone recommend me how to scan my phone or do i need to format my phone to the original factory. if do, how could i format?
Thank you in advanced.
Forgive for my poor english:redface:
My N80 is infected by virus W32/Rontokbro.gen@MM
It might be that your phone is fine, but the files you downloaded contain the virus
well u can try Fsecure but, i dont think ur Phone is infected
Or Symantec - cames with N70 original card.
didnt know that
But, I realize, that couldn�t be used in N80 - diferent OS version!!!
Maybe are a Symantec OS9 version. I don�t know right now.
No need to worry about your phone, since it is quite clearly not a phone virus, but rather a mass mailing worm that could only be executed and operate in a windows environment. It's even written in visual basic, according to McAfee virus base.
So if anything, you should be concerned about your Windows machine. But since it seems that you're protected with an updated virus scanner, there's still no need to worry.
Just delete the file on your memcard and make sure you haven't executed the worm on your PC, by simply making a full virus scan.
Read about symptoms here:
http://vil.nai.com/vil/content/v_136318.htm
cool no virus, anyways is there any virus for S60 3rd??
S60 3rd is relatively new and I haven't heard virus on this platform yet.
Besides, that S60 3rd introduces Platform Security that makes virus infection more difficult. IMHO, it would take some time because they can "compromise" Platform Security.
I am interested to see how viruses can spread in S60 3rd too... 😊
antonypranata wrote:S60 3rd is relatively new and I haven't heard virus on this platform yet.Besides, that S60 3rd introduces Platform Security that makes virus infection more difficult. IMHO, it would take some time because they can "compromise" Platform Security.
muahahaha :evil: my first 3rd edition app will b a virus muhahahaha it will drain ur batt in just a sec lol and if u plug it to the charger will drain earths power muahahaha so mr Bunny gill conquer the world :con?
_Dx_ wrote:muahahaha :evil: my first 3rd edition app will b a virus muhahahaha it will drain ur batt in just a sec lol and if u plug it to the charger will drain earths power muahahaha so mr Bunny gill conquer the world :con?
So I guess we all have your virus already then judging by our battery life 😉 😉😉
damn somebody won me about the virus damn u nokia!!!! 😃
