I cant play MP4 on my N70. I used IM TOO software to convert my video file. I have no problem to play it on my PC, however, it cant play on my N70. I have real player on N70. Any help pleasessssssss?
MP4 player on N70
N70 record video in MP4 format, and play the same format. When you made the conversion, you select same diferent configuration?
I choose MP4 format also from my AVI file, however, it still doesnt play, always give me an error 😡
The mp4 file from N70, is a 352x288-15fps. The encoder must produce the same thing!
nj7 wrote:The mp4 file from N70, is a 352x288-15fps. The encoder must produce the same thing!
Actually thats not true. I encode videos using QuickTime pro with MP4 video and AAC audio, 15fps and 208 *176 resolution. They play quite happily in RealPlayer. I will be happy to help you get things encoded in this way or provide working examples.
Gary Fitzhugh wrote:Actually thats not true. I encode videos using QuickTime pro with MP4 video and AAC audio, 15fps and 208 *176 resolution. They play quite happily in RealPlayer. I will be happy to help you get things encoded in this way or provide working examples.
Sure. I made a correction, max 352x288-15fps!
Good call 😉
Imtoo converter is not compatible with N70 codec specification for some reason. Anyway, Just use some other converter, there are several more out there, that can convert into mp4 format.
