pls help, i buy lousy n80..
4 replies · 2,448 views · Started 18 July 2006
i alr try to follow u all give tips how to save batt, but result still same..
And my n80 cant gt connect to wifi internet, wat should i do?
And 1more thing is my gallery smtime will missing inside item etc😛ic,mp3..
all above wat should i do.. pls give any tips/ sugguetions..
could you please dial *#0000# and post here wut ur screen shows?? that will b helpful
stephenfei wrote:i alr try to follow u all give tips how to save batt, but result still same..
Also dont expect your battery to increase in life too much, the battery saving features mentioned here will probably extend the battery if you do not use any of the smart features, as soon as you use something like wifi for example the battery will drain very quickly.
with Mp3 you have to update the library everytime you add mp3's, i dont know why is doesnt do this automatically, but there we are .
I sometimes get missing pictures when looking through the gallery, but the pics are there when you transfer to your pc, I can only think this is a bug and if Nokia know about it should hopefully be fixed in a later fw update.
Will need more info in your wifi problem, what error do you get when trying to connect, etc
stephenfei wrote:my ver
V3.0617.0.6
03-05-2005
RM-92
NOKIA N80,
how its any prom??
And N70 software or theme cant install to N80??
No You can�t. Diferente OS version!
