Phone Memory Question...
7 replies · 1,843 views · Started 18 July 2006
Right when your in File Manager you can view Memory details. My phone is showing Memory in Use - 36MB! A friends phone is showing 19MB in use. Is there any way i can see whats taking up all the memory? I only have 6MB of pics in the phone memory the rest are 91kb, 3KB & 20KB!! Where has it all gone... :frown:
Anyone else know whats going on?
Cheers!
Wez
Wez69 wrote:😡
Cheers!
Wez
did you install many apps yet, I found that some of mine were being installed to the phone mem instead of the card mem so I deleted and re installed
Yeah i have a couple apps but i thought i had installed to the memory card as the app memory status is 0k :con? Ill delete them and try reinstalling them see what happens.
The FExplorer or TaskSpy will those work on our V3's? I would like to gove that a go too..
Cheers guys :icon14:
Well ive uninstalled all programs from the phone and the memory hasnt changed! :frown: And those programs do not work... Any other ideas?
Wez69 wrote:Well ive uninstalled all programs from the phone and the memory hasnt changed! :frown: And those programs do not work... Any other ideas?
goto file manager and check the installed files folder for anything that shouldn't be there
I done that but no luck... Ive resorted to a Format of the phone! I then had 5MB Memory in Use. I then done a back up restore and have 16MB Memory in use! 6MB of that is 6MB! I can live with that... Cheers for your ideas chaps! :icon14:
taskman might had helped u, about Fexplorer, i talked to Domi, and he says tha Fexplorer is under development right now, i hope he finishes it soon
cheers
Dx
