I've heard that you'll need a high-performance memory card for continuous max resolution video capture on the N93. So my question is, will a "SanDisk Mini-SD Ultra II 2GB" (http://www.tbh.se/index.asp?id=7&kat_id=1317&prod_id=10458) do?
Which memory card to get for N93 video capture?
Nobody have the experience, already. But, to have the capacity of capture such amont of bits, the more faster be the card, better! By my experience in DSC, I think it needs to be more than 60x.
Hmm, I see. Well, the manufacturer's web site (http://www.sandisk.com/Products/Item(1880)-SDSDMU-2048-SanDisk_Ultra_II_Mobile_miniSD_2GB.aspx) claims that it has a write speed of 9 MB per second. If that's true, that should be more than enough, right?
I've ordered a datawrite one nice and cheap.
http://www.burn-media.co.uk/product.php?productid=930087
£29 for 2Gb one.
And checking Datawrite's website it states that their mini SD cards are 24Mb/sec Read 20Mb/sec Write so more than fast enough.
I think that N93 video uses about 20-30 Mb per minute so no problem there.
Dylan
(Although I'm not sure if the read/write speed in MegaBYTES or MegaBITS, both would work out fast enough )
Enfors wrote:Hmm, I see. Well, the manufacturer's web site (http://www.sandisk.com/Products/Item(1880)-SDSDMU-2048-SanDisk_Ultra_II_Mobile_miniSD_2GB.aspx) claims that it has a write speed of 9 MB per second. If that's true, that should be more than enough, right?
It�s a 60x card. Should be enough!
