E61 / SmartMovie and a Mac
4 replies · 3,313 views · Started 18 July 2006
Please, someone tell me how is the world I can convert movies to play on my phone using smart movie from a Mac
I tried Forty-Two, worked fine (so it seemed) but no audio ...
No I am trying FFmpegX using the AVI Xvid setting and the progress is at 150% , 150%, WTF
PLEASE HELP
arythmic wrote:Please, someone tell me how is the world I can convert movies to play on my phone using smart movie from a Mac
PLEASE HELP
By far your best bet is simply to use Apple's Quicktime Pro, exporting any movies you want in MP4 format - you'll find the E61 can play them just fine. See for example the MP4s I create as part of the Smartphones Show:
Steve
This works fine for playing movies in Real Player, which doesnt allow you to FF or RW (what is up with that)
Hence why I bought SmartMovie, and smartmovie isnt recongnizing .MP4s ... Is it supposed to ?
slitchfield wrote:Of course you can fast forward and rewind in RealPlayer - just hold down the up or down navigator keys.
Yes, FF and RW work fine.
Even my N-gage's real player allows you to do this.
