Codes for info and or reboot
8 replies · 2,442 views · Started 19 July 2006
Is there a list of the codes that can be input into my N80 to see what info can be seen on the phone i.e. serial number and also for rebooting the phone either hard or soft.
Neil
I was given a hard reset code by Nokia which I wrote down but now cannot find the paper. I think it was 'star hash 7370 hash'.
Simon
*#7780# - Reset to the original settings; some informations are also deleted and need to be re-entered.
*#7370# - Soft format - this will resets all the phone memory (like re-format a disk); make sure to have full battery charged !
[Green]+[def3]+[*+] during a power on performs a hard format : this will return the phone like you have received; make sure to have full battery charged !
cheers
Dx
