Installing Security Certificate N91
10 replies · 14,675 views · Started 20 July 2006
How do I install a Personal Security Cerificate in N91 ? What format does N91 Support ? And how do I export the certificate in that format from the PC ?
Thanks in Advance
theintelligent wrote:How do I install a Personal Security Cerificate in N91 ? What format does N91 Support ? And how do I export the certificate in that format from the PC ?
Thanks in Advance
For sure, it shoul be Symbian or JAVA - only chance to install anything in a N91!
The N91 supports the DER/CER format.
1) Get a .CER (the certificate) file
2) Using PCSuite, copy that .CER file to your phone in any folder really. Documents will work
3) Using FileManager on your phone, navigate to the file, and you should be able to "open" it, and then it will say do you want to import it
These certificates you talk, are validation codes, to use in e-mail, when comunicate with autorities, or private organizations, like the ones used in Outlook - on a PC? Digital signatures? Is that?
Certificates are for security and yes they are about communicating identity (it's a bit more than that, but I'm not an expert). S60 has a lot of these preinstalled (e.g. the ones used on many SSL websites), but sometimes people need to add thier own. The most common is for email servers.
Thanks! I understood the first question badly. I thought that the problem was to install, how / what kind, to install... Then I realize, the mistake I had made. Thanks again for the clarification!
Rafe wrote:The N91 supports the DER/CER format.
Does this hold true for any S60 3rd Ed device?
I answered the question myself. May it be helpful for anyone.
Just use openssl to convert the cert like this:
openssl x509 -outform der -in MYCERT.pem -out MYCERT.der
Then proceed as described above (.der seems to be pretty much the same as .cer, at least my N91 accepted it).
Cheers
Wirelessly posted (mreduls computer and mobile.: NokiaN91-1/3.0 (2.10.013) SymbianOS/9.1 Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Thanks in Advance
MREDUL.
I had dis themes installed in ma fone...which i could not remove frm da fone bcoz dey wer not present in the so called APPLICATIN MANAGER..
and hence i had to format the memory card. through which i lost the autolock application..i searched it in da net...but wz unable to get dat software....
could any one of you help me find that software...
[email][email protected][/email]
