Capabilities for App using CBrCtlInterface (Browser Control)
7 replies · 0 views · Started 20 July 2006
My S60 third edition app uses Browser Control APIs which require
following capabilities,
NetworkServices
ReadDeviceData
WriteDeviceData
Now the last 2 capabilities are not provided by self-signing as well as
using developer certificate from symbiansigned.
Currently I am able to create the sis file and transfer and install on
s60 3rd Edition device. But when I try to launch it, it
does nothing.
Can anyone throw light on this ??
Thanks,
Anand
Anand Kale wrote:
> Hi,
> NetworkServices
> ReadDeviceData
> WriteDeviceData
> does nothing.
> Thanks,
> Anand
All 3 capabilities are available with a dev cert.
AMK
Anand Kale wrote:
> Hi,
> NetworkServices
> ReadDeviceData
> WriteDeviceData
> does nothing.
> Thanks,
> Anand
All 3 capabilities are available with a dev cert if you have an acs id
cert.
AMK
To see if it's the capabilities which are preventing your app from
launching, look at the debug file EPOCWIND.OUT in your temp directory (you
may need to turn PlatSec diagnostics on in your epoc.ini file) to see if
you're getting any PlatSec violations.
See FAQ-1340 and FAQ-1344 for more details.
Mark
Symbian Developer Network
Thx for your replies ...
I have Dev Cert using the IMEI# and not using ACS Id. I guess the last 2
capabilities are not supported in this Dev Cert.
Please confirm ..
Thx,
Anand
"AMK" <[email protected]> wrote in message
news:[email protected]...
> Anand Kale wrote:[color=green]
>> Hi,
>> NetworkServices
>> ReadDeviceData
>> WriteDeviceData
>> as using developer certificate from symbiansigned.
>> on s60 3rd Edition device. But when I try to launch it, it
>> does nothing.
>> Thanks,
>> Anand
> cert.
> AMK[/color]
All Dev Certs must be tied to IMEI number(s), so that's not relevant
The choice (in step 2 of the Dev Cert Request) is to either use an ACS Pub
ID or a private ID. To get a Dev Cert with ReadDeviceData & WriteDeviceData
you'll need to use an ACS Pub ID.
Mark
"Anand Kale" <[email protected]> wrote in message
> Hi,
> Please confirm ..
> Thx,
> Anand
Mark,
FAQ in Forum Nokia ??
Also is such a file created on device. I am able to see the browser control
in the emulator; but not on the device ..
Thx.
Anand
"Mark Shackman" <-> wrote in message
> Mark
FAQs on Symbian.com
ie
http://www3.symbian.com/faq.nsf/AllByDate/138E15D7FA8E656D802570C0001BDB3B?OpenDocument
> Mark,
control
> Thx.
> Anand
> news:[email protected]...[color=green]
[/color]
(you[color=green]
> > Mark
>[/color]
