max number of bluetooth connections already in use?
5 replies · 3,397 views · Started 30 November 2002
"Unable to connect. max number of bluetooth connections already in use"
Has anyone has this error? This happens anytime I try to send something to my PC via BT. I can do everyting else apart from send.
This error message appears if you have a connection with mRouter and try to send an Images for example from the phone to the PC. The 7650 thinks that it sould initiate another connection which is not possible! Sending from the PC to phone works just fine even with mrouter connected but not vice versa. Disconnect from mrouter and try again. Make sure that there is no "(o)" displayed but only a "o".
Excellent, thanks alot m8. One thing though, When I try to use bemused with this method I get a -25 error?
I really cant help you with that, but I know the developer of this application can. just wait and he will answer. I only know that mrouter must be disconnected too.
[quote="Roysters"]Excellent, thanks alot m8. One thing though, When I try to use bemused with this method I get a -25 error?[/quote]
I had the -25 error on the handset while trying to connect to my PC... In the end I turned BT off on my handset, killed the bemused server on my PC, killed my Mitsumi BT USB dongle app... restarted everything.. still no cigar..
Ended up removing and reinstalling the bemused client on my handset.. worked a treat 😊
I've seen this "error -25" problem happen before with Mitsumi Bluetooth dongles. I'm afraid that Bemused just seems to not be compatible with some of them 😞 Sorry.
