Problems Uninstalling Applications From My Sony Ericsson P910i.
3 replies · 6,497 views · Started 20 July 2006
Hello
The problem with my Sony Ericsson P910i is that the applications dont get uninstalled due to some reasons and I am just getting worried with this problem as i dont want to reset my p910i and everytime I try to uninstall I get the error message :
a problem accured during uninstallation Access Denied.
and when i reboot my phone i get error message at startup :
not found
Does anyone have a soloution for this problem? and are these problems have anything to do with any previous reset of my smartphone? and will upgrading firmware solve this problems?
currently I am try to uninstall > 1.Trend Micro(tm) Mobile Security for Symbian(tm) UIQ Edition Version 1.0 - GM, 2.SMan v1.2c, 3.Mobila Web Camera UIQ ver.1.0 Warelex 2006.
My Mobile firmware:
Phone: CXC162042 R4D006.
organiser :CDA162005/6 R4A10.
Thank You.
One method you could try is reinstalling these application and then uninstalling them. You also need to makes ure the applications are shut down / closed. Some of the ones you mention are memory resident.
Hello,
I tryied to stop the running applications but still it wont work and even reinstalling fails and cannot be installed.
Is there any software for SE P910i that can compleatly stop the running application and also uninstall it compleatly?
Thank You For Your Reply.
hello..
can any body help me how to find a driver for p910i
phone: cxc162042E008
blue tooth: cxc16228/1R2c
cda:162006/5R1b01
thank you..
nonaem
