cant send mms on o2 uk
5 replies · 2,551 views · Started 30 November 2002
😞 help i cant send mms from my n7650 my settings are
prefered net ..o2 mms
secondary... o2 mms
multimedia reception ..always on
on reciving msg..retv immediately
allow anno msg..no
receive adverts...yes
recive report... no
deny report sending...yes
msg validity...max time
image size..small
speaker ..loadspeaker some one help :P
Try this,
Go to Tools>Settings>Connection>Access points and create a new access point with the following settings(which work for me):
Connection Name: Whatever you want
Data bearer: GPRS
Access point name: wap.o2.co.uk
User name: o2wap
Prompt password: No
Password: wap
Authentication: Normal
Gateway IP address: 193.113.200.195
Homepage: http://mmsc.mms.o2.co.uk:8002
Connection security: Off
Session mode: Permanent
Set this as your default access point under mms settings.
still dont work msg jus goes into out box say resend at like 10mins later do i have to register for mms or sommit im on contract?
ahh, yes. You do have to have MMS enabled on your account. Although good luck getting any response from their email support, I ended up having to phone them on the 50p/min line :evil:
i had same problem call o2's technical department on 084560006886, explain your prob and if need be they will txt you the settings and then you simply save the settings, worked for me. 😉
what you must do, is phone up your billing company, and tell them to update your tariff, you can get all the old tariffs except just with the ability to send mms. theyre the same price, the only thing that's different is that you can send MMS, but youneed to phone and ask for this to be done.
