Problem with my N91's phone memory
9 replies · 3,703 views · Started 22 July 2006
Hi! Just need help from my fellow N91 users. I think i have a problem with my phone memory, it constanly increases even though im not installing anything. I already upgraded my firmware version to 1.10 and it still increases. is there a setting on the phone that can solve this? Thanks in advance for replying
ei! thanks for replying. i already did that a couple of times but it still increases after a few days. i even took it to the nokia care centers and they just did the same. any other ideas? (",)
Do a test! Soft format, and install one by one the new things, and watch what happens with memory. One of them must be the culprit.
hmm....i been thinking, when you install something on hard drive, it still takes memory up in your installed files folder in your phone memory and make sure you delete the files which are created in there, they will not affect your phone.
reply back and let me know
If the original installation goes to HD, the the install file, is also in HD. It does not have to be that it increases the memory.
when u install something in hard drive, the installed file is also placed in the INSTALLED FILES folder in PHONE MEMORY, make sure you delete them files in there, they will not do any harm.
ahhhhh! now my n91 doesnt have any audio! i tried turning it off for more than a day, i reformatted both phone and memory hard drive. any ideas guys? is my phone jinxed or something? i was just listening some music, and then suddenly it lost sound. i tried inserting the earphones and it worked. its the loud speaker im having trouble with
Hi
I saw on another blog that someone had a similar problem. repair centre just popped off the back plastic cover and clikced in something. Speculated the people in the Nokia factory did not snap the spkr in all the way. Could be your problem too...
musi101
