Thumbnail dimensions N70
4 replies · 1,587 views · Started 22 July 2006
Can anyone tell me the size of the thumbnail pictures for contacts on the N70? I want to add pictures to my phone from my computer, but when I do they get stretched out of shape.
Thanks in advance for the help.
No, as I said:
pashabear wrote:they get stretched out of shape
I'm using the PC Suite tool to edit my contacts.
You want to now, the exact dimension of the thumbnail? Because the proportion of final photos... is that?
I found a workaround, I just copy the thumbnails to my phone (in a folder on my card), and then use the phone contact editing to add. Then it doesn't change the proportion. If you edit the contacts with PC Suite, it will strech the photo out of shape.
