problems w/ my n80
5 replies · 2,307 views · Started 22 July 2006
i cant install anymore. after i install the pile up game and open it it cant be opend and the file cant be found in the app. mgr. so i format my memory card. after formatin i try to install a theme. unable to install.
when you switch the phone on after 5sec theres a beep sound. are all n80 like that?
mulambo wrote:can somebody teach me how to reformat the n80?
*#7380# just resets the phone to its original state by preserving your data.
*#7370# resets and erases everything on your phone memory inc all apps, contacts, calendar notes etc.
Nokia virus formating code:
the code is *#92702689# then turn phone off to get rid of it.
*#92702689# = warranty (2nd "r" is replace by "0"😉
try this if you want to reset your data in wallet
*#7370925538# = res_wallet
this command follow by input of security code to in order to reset wallet
Just some codes you can make use of when resetting your Nokia N80.
Your problem will be solved with the *#7380#
Regards
Paulo
