I tried recording some songs thru the recorder, but im experiencing some problems w/ it. It somehow, fluctuates. Meaning....the sounds I've recorder gets choppy. It get pauses every second. So it sounded like a skipping/ damaged CD.
I installed it over and over again but still the same result. I only experienced this after I formatted the whole device. What's wrong?
Help. Thanks
Help in the Recorder
I think this is a common fault I also experience this when trying to record music and car sounds, its annoying but then again that recorder programme is a bit naff! :roll: :roll: :roll: :roll:
Try changing the audio quality to normal. When it's set to compressed it records real bad!!!!!!!!!!!!!!!!!!!Recorder-tools-settings-audio quality:normal.
😃 :roll:
change it to Compressed,
and try to use a 8MB MMC or maximum 16MB to record Normal quality.
but when using a 64+ MMC change it to Compressed.
Good luck 8)
Thanks guys. I got it already. The recorder stopped fluctuating already.
What I did was changed the default folder to Memory card from Communicator. That did the effect.
Thanks guys. 😃
Boys 😉 ,
When I am recording a ring tone with my Communicator I use Ring Mater.
Hven`t you heard of it?
It is great, you can even select the lenght of the ring tone :roll:
[quote="apcaw"]I tried recording some songs thru the recorder, but im experiencing some problems w/ it. It somehow, fluctuates. Meaning....the sounds I've recorder gets choppy. It get pauses every second. So it sounded like a skipping/ damaged CD.
Help. Thanks[/quote]
This happens when you're low on disk memory. At least it solved itself after setting recorder to record on d instead of c. That's why changing to compressed could also work.
[quote="TheSpecialBoy"]Boys 😉 ,
It is great, you can even select the lenght of the ring tone :roll:[/quote]
I know about RingMaster. Its just that here in my country, the foreign exchange is soooooo high that it's really not that practical anymore to buy. So, sad to say, I have to work with what I have. 😞
