Everytime i try to transfer music using wmp 10 or music manager, the phone and the wmp10 and music manager hangs up. I have to do a reboot for the phone and when I try to play music, some music cant be played or when i try to search for songs or try to skip songs.. the phone hangs up again. I tried to access the phone using mass storage but i cant open some folders like my music..and some others... sometimes i cant even access the hard drive... someone please help..
n91 hard disk problems
i have an n91 mobile.i can not able to access to my hard disk,so pls can anyone help me out.wat cud be the problem?
Does anyone have any idea what is causing it?
I tried reinstalling the nokia suite and rolling back to wmp 9.
The problem i have is with drm encrypted music, the ONLY way to transfer drm music on a n91 is via usb with windows media player 10 so if it aint working then you would have to burn to cd rip back again with wmp 10 and remove the drm but that is a pain and why pay for a cd when you dont need to .
<--!I have no idea why this is suddenly not working on 2 machines with win xp sp2-->
Annoyed.
Btw hockey
No idea why you cant transfer using mass storage that works for me and drm music will transfer but it wont play.
This may help
n91mac.wordpress.com/2006/07/18/nokia-n91-how-to-perform-a-hard-reset/
mangababu what exactly have you tried to do --- more info the better.
Hi
Take a look at these tips. Also the N91 8GB stuff (uder guide and tips) talks about WDRM etc. Its applicable to 4Gb as well
Cheers
19 tips: http://www.ohgizmo.com/2006/10/19/top-19-tips-to-get-the-most-from-your-nokia-n91
Nokia Tips Guide (just select the language to use)
http://europe.nokia.com/A4158098
http://europe.nokia.com/A4213023
