need a mic
6 replies · 1,861 views · Started 23 July 2006
I have problem with the mic now.
i need a replacement mic, in sendosmartphone it shows out of stock.
where else i can find
Regards,
Venkatesh
Not sure if that's gonna help...You could try cleaning the contacts of the mic and the phone and then maybe using some contactspray. Good luck😊
Sendo Smartphones is attempting to get more stock of microphones, unfortunately sourcing them is proving dificult.
In the meantime, cleaning the contacts on your existing microphone should make it work again.
stuclark wrote:Sendo Smartphones is attempting to get more stock of microphones, unfortunately sourcing them is proving dificult.
stuclark,
I have cleaned the contacts if the mic now its working but again after few days am getting the same problem
So i always have to carry a headset to make sure ppl hear me :frown:
Regards
Venkat
I also had this problem and could solve it usually by slackening the case and retightening. The problem would always come back at an inconvenient moment. I then carried a bluetooth headset around with me and used it because I didn't trust the microphone. Eventually I removed the microphone, cleaned its contacts, and cut some small pieces of card to push into the housing where the microphone sits. The object being to press the microphone more tightly onto the PCB. This has been fine and no more troubles from the microphone for a year now.
HartPD wrote:I also had this problem and could solve it usually by slackening the case and retightening. The problem would always come back at an inconvenient moment. I then carried a bluetooth headset around with me and used it because I didn't trust the microphone. Eventually I removed the microphone, cleaned its contacts, and cut some small pieces of card to push into the housing where the microphone sits. The object being to press the microphone more tightly onto the PCB. This has been fine and no more troubles from the microphone for a year now.
I tried everything, as you said it comes at inconvenient times, so i gave my phone got a new A780
