Unable to delete files copied as read only in ngage qd - gettin system error
4 replies · 6,354 views · Started 23 July 2006
I copied some installer files (.sis) into my mmc thru a card reader as readonly fles. When i tried to install them, the .sis file got copied to c:\nokia\install and am unable to delete it (getting system error). Even i was unable to delete those read only files from MMC using fexplore.. It was only ater a while that i realized the problem was due to the file being read only. When i removed the readonly flag from the files in mmc thru the card reader, fexplore was able to delete them.
Bit those in the phone memory is occupying a lot of space and i am unable to install any new softwares as a result of low memory. can someone suggest a way to delete these files from the phone memory?
HI!! i need some help....i have a nokia n-gage QD......i've installed there some software, psiloc software.......the system tools and the extended profiles pro.....i wanted to unnistall them but when i try to do that, some message apears saying that there's an error on the "manager"....what can you do to help me unnistall that software? please help.....
PS: Sorry for my bad english.....i'm portuguese
karthik123 wrote:I copied some installer files (.sis) into my mmc thru a card reader as readonly fles. When i tried to install them, the .sis file got copied to c:\nokia\install and am unable to delete it (getting system error). Even i was unable to delete those read only files from MMC using fexplore.. It was only ater a while that i realized the problem was due to the file being read only. When i removed the readonly flag from the files in mmc thru the card reader, fexplore was able to delete them.
Sorry. i don�t understand. If You are able to delete or not?
bogas38213721 wrote:HI!! i need some help....i have a nokia n-gage QD......i've installed there some software, psiloc software.......the system tools and the extended profiles pro.....i wanted to unnistall them but when i try to do that, some message apears saying that there's an error on the "manager"....what can you do to help me unnistall that software? please help.....
Use FExplore, and go to E:\system\apps\ then the software You want to clean, and erase them.
i think ya got to use SeleQ, and go to the files and select properties, unmark READ and then try to install agian sis.files...
if ya dont have SeleQ, put ya mmc and use PC, right click sis file, unmark READ...ok
