How can i uninstall applications / themes which are not in the application manager?
uninstall applications nokia 3250
Just go to the theme section, and do a erase them - uninstall the themes!
When you connect your mobile with Nokia Pc Suite or Data Manager, Just click on tools and select the option "show hidden files and folders" in your computer, then in data manager/pc suite , select Folder named Private then, clcik on this folder "0207114" then, in that one more folder "import"
Then there will be many folders wirtten by numbers on it ...click on each and check your theme named which was giving you problem .....then simply delet that folder.....:icon14:
i am not able to find the folder named ' private '
am using the nokia pc suite 6.8
i have tried what all u said.. still unable to un install certain themes..
Connect the phone using the Data Transfer mode n not the PC Suite mode.
Then go to the private folder , you will be able to access it.
And go to that folder and delete the themes you want to delete.
thanks
[freshman]How can i uninstall applications / themes which are not in the application manager
alsiladka wrote:Connect the phone using the [SIZE="3"]Data Transfer mode [/SIZE]n not the PC Suite mode.Then go to the private folder , you will be able to access it.
SO HOW DO I CONNECT USING ((Data transfer mode??))!!
The easiest way that worked well with my Nokia 6120c is to remove the memory card, read it by a USB reader, and manipulate the 'private' folder in the way mentioned by 'Manduck'
the easier way is to take off the card and edit it using a card reader/writer
Can u help me in hacking rom of nikoa 3250? i tried all methods i've got on forum sites like HelloOX2.02/03 and HelloOX 1.3/4 i signed them with Cer and key that i got from cer.opda.cn but still not workign after instalation it stucks sometimes on applying patches and sometimes on unpacking files ? and also tried OPDA hacking tookit but nothing works and i am using newer firmware of 3250 v4.60 can u help me ?
freshman wrote:How can i uninstall applications / themes which are not in the application manager?
After using my nokia 3250, Im not able to install new app. & also uninstall app. Which r not working at all. Please help me to solve these problem.
