Nokia PC Suite doesn't sync Outlook Calendar
1 replies · 7,925 views · Started 24 July 2006
I've just installed the last version of Nokia PC Suite (6.80.22) and surprise...it doesn't sync my appointments and the calendar.
Only the contacts sync works well.
Any suggestion ???
Thanx...
Only a suggestion, not sure...
Uninstall all, remove all registry entries, eith a Reg Clean program, reboot, and install again. It may work!
