Hi
Can anybody out there help please. i have a nokia n70 and tomtom5 nav and holux 236 gps my problem is the nav. keep loosing signal and freeze. please let me know what to do will appriciate
john
help
READ the forum - it says all about it.....
BASIC... THE GPS adapter can not be under bluetooth setup in the nokia....
Simply start tomtom, run find gps under tomtom settings - accept or type in the code 0000..... Then close tomtom - go to the bluetooth setup on the nokia, remove the adapter if its there... Restart your phone.....
NOW::: 9 out of 10 times tomtom does not say anything about the gps adapter,
now it will work - if tomtom wants a code to connect to you gps, just say no - it will connect anyway....
