Guys,
As SonyEricsson looks to finally be releasing the P990i and there's a Bluetooth Stereo Headset available and it's compatible I'm wondering about the music capacities of the P990i.
On the P800 I wouldn't have used the MP3 player as more than a "Put it to play and be ready to use both hands if something needed changing"-player. Not as a "true" MP3 player which you can keep in your pocket and stick your hand in there and skip forward or up/down the volume.
The P990i is much more refined as I assume it's gotten a dash of the Walkman capabilities from the other W-series phones. It's also got the advanced Bluetooth Profiles which allows you to use the HBH-DS970 headset.
http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=pp4_1_1&zone=pp&lm=pp4_1&pid=10394
Here's what I'd like to use my "music player" for; Commuting on the train and tube into London. Almost 4h per day in total. I'd also like to use it on my motorbike. I go for long rides, sometimes 8h or more. This means that my phone, if turned on, would be roaming between countries and so forth.
My choice is basically to either use the P990i + Stereo BT headset and use it for everything. Or use the P990i less, and get a separate small MP3 player.
I've been thinking about the Samsung YP-U2QB
http://www.amazon.co.uk/gp/product/B000ES002Q/026-9017677-4876408?v=glance&n=560798
The benefit of using a separate MP3 player is that I won't kill the battery on the P990i whilst listening to music.
The benefit of using a BT headset with the P990i is that I can get all the sound out of the P990i... and any other BT device that's capable - maybe a future laptop? I could get on the train listening to music, then turn the music off, switch to watching a movie on the laptop without taking the headphones out.. 😊 There's also a slim chance the microphone would actually allow me to answer a phone call whilst riding the motorbike. I could definitely stop and make a phone call without taking my helmet off.
I guess it largely comes down to the batterylife of the P990i (and the BT headset - the MP3 player has got 13h battery life!)
At the moment I'm leaning towards a separate MP3 player...
Any thoughts?!
