Phone Lock Code Blocked
6 replies · 24,178 views · Started 25 July 2006
I've Nokia 6600. I activated Autolock Phone Lock. My younger brother tried to unlock with wrong password & the code is blocked now. Now I cant use my phone 😞
Please tell me, how can I unlock my phone ????
After 3 wrong codes the phone locks, for security reasons. You already know that! Now, try a Hard Reset - Same time, Green Key + * + 3 and Power On. You lose all... If that doens�t work, go to a service point, make prove that You are the legitimate owner, and they unblock the phone.
I already have tried that RESET but no use...
I'm purchased 2nd hand (used) mobile phone & I dont have any legal documents. 2nd prob is.... I'm in a very small city, there is not any NOKIA Service Center. Can u plzzz tell me about any trick or any software which could unlock my phone, I'm in a great problem.
I don�t know other legal way. Even if You are far way of a Nokia Service Point, You can send the phone by mail. But You need to talk with them, to know if is possible to do the unlocking process, without a prove of legitimate owner.
:icon4: i have a sony erricson k750i havnt used it for ages n forgot the code to unlock it. is there any way i can unlock it. i had it from my cousin so its not registered in my name. pls pls pls help me
woodyjr52 wrote::icon4: i have a sony erricson k750i havnt used it for ages n forgot the code to unlock it. is there any way i can unlock it. i had it from my cousin so its not registered in my name. pls pls pls help me
Ask your cousin to do it instead of you.
Uzair693 wrote:I've Nokia 6600. I activated Autolock Phone Lock. My younger brother tried to unlock with wrong password & the code is blocked now. Now I cant use my phone 😞
You can try to do a master reset to your Nokia 6600. doing so could restore your phone to default factory settings. Including your security code to default "12345". You can get the free master reset code for your Nokia 6600 from http://www.unlock-free.com/nokia-master/ Good luck mate.
