I used to have a Nokia 6230i which worked perfectly with the headset. I have recently upgraded to an N91 which also works very well apart from one thing.
When I receive a call I can't get the phone to auto answer even though it is set up to. If I plug a headset directly into the phone it will auto answer after 5 seconds which shows the option does work. The Jabra, however, will not auto answer.
The reason I bought the Jabra was for use on my motorcycle. It is perfectly shaped to fit behind your ear and will auto answer without having to press buttons on my phone (through leathers near enough impossible) or the headset as it is inaccessible with my helmet on.
Is there something I can set up or upgrade to make this headset auto answer calls?
Sorry should have said Jabra 250v
