Disc2Phone
6 replies · 5,604 views · Started 25 July 2006
I am trying to use Disc2Phone, included in the suit, to transfer songs and possibly see the functionality of the software but it apparently does not recognise my Phone.
Everytime I open the software and try to locate my phone it says:
'You must Insert Memory Stick or Connect your Phone with USB"
Anyone else having problems with it? If so, any suggestions?
Many thanks,
M
P.S: Just downloaded Google Maps for M600i and it ROCKS!
Have you changed your USB setting to 'File transfer'. From the main screen go to: More - connections - USB and then select 'file transfer'. I think you need to disconnect the phone from the cable before you are able to make this change.
Good luck:icon14:
For some reason I cant find this setting that you mentioned. Is it in Disc2Phone or m-Router?
In Disc2Phone, all I see is 'Music Source' (Greyed Out), 'Add', Transfer List icons.
This is how it looks (See Attachment), I dont see any other toolbar:
:con?
Attachments: screen.jpeg
Thanks for the answer. It seems like this forum work better and faster then waiting reply from Dsik2Phone, or either SonyEricsoon Website.
Thanks for this.
A help function/instructions would be useful.
That said it works well once in place, with superb sound quality through bluetooth stereo headphones.
