cleaning
1 replies · 1,600 views · Started 25 July 2006
hey, wondered if ny 1 had any quickfire tips on cleanin g the n80,
over the past few days, i dont know how, but my n80 has acquired some faint scratches horizontally across the screen and something has found its way into the slider mechanism makin it fel like sand or grit is under the slidera nd at time this can be seen ,
do you know and ways of cleaning this ?
thanks
simmatt wrote:hey, wondered if ny 1 had any quickfire tips on cleanin g the n80,
thanks
Do a search in this forum and you will find a thread that explains how to dismantle the N80, good for if you need to clean it,
There are products on the market that will clean the scratches, very very fine abrasive cleaner (some car body repair shops have them when they have to remove scratches from windows), but use at your own risk.
I decided that if my screen gets that badly scratched then I would just buy another body for the N80, they are really quite cheap.
Hope that helps
