FLASHLIGHT AS ATORCH "Best"
23 replies · 10,945 views · Started 26 July 2006
Finally there is ...... :rock:
App called "flashlight" It uses camera flashligt as a perfect torch
1 - Install sis file
2 - Start camera and press "menu" button to hide it
3 - Start flashlight app and write code "15001" and press "test" from options menu to activate
How to close
1 - Exit from app. Open it again and write code "15000" and press "test" to deactivate.
WORKS PERFECT ON MY N70
Thank me later.....
Attachments: flashlight.zip (5 KB)
jonnycraig wrote:Just installed it. Camera LED only flashes like taking a pic, wont stay on, any ideas!!
JC
Same to me!
nj7 wrote:Same to me!
same to me at the first..
i try to insert code 150001 .. it's done...
happy try
insert code 150001 and choose "test" from options while camera running backwards
if u can't again, i can post prewiew pıcs how to use.
It's a bit hit and miss in operation!
I found this was the best way, with slider shut to begin with:
1. Run Flashlight
2. Open camera slider (this way round there's no camera running in the background)
3. Type 150001 (not 15001, sbyugen - at least get that part right!)
4. Exit Flashlight and use the torch as you want to
5. Open Flashlight
6. Type 15000
7. Close Flashlight
8. Close slider.
Blindin' 😎
thanks drofidnas, noone said anything about having to close the flashlight program and then open it again to turn off the flashlight
ratza wrote:Guys, what firmware do you have? On my 2.0536 doesn't work at all. Just exits.
My firmware version is 2.0539.1.2 (Vodafone branded). The program works without problems on my phone.
I have a little problem with Flashlight. The light only works when I insert the code 150001, yes 150001 and not 15001. I couldn't think up a code to turn the light off. The only way to turn off the light is taking a picture with my camera. Maybe there some others with this problem. Try to take a photo to turn your light off.
Flashlight does work very well fot my N70 when I use this technique. It is a little extra work but from now on I can use my mobile as a Flashlight. Thanks for posting!!
There is another app called SpotOn but the light emitted y the flash is low, exactly how it is when recording video. It is the same for Flashlight? Can you tell if you can record videos with the flash on?
Patrick_89 wrote:I have a little problem with Flashlight. The light only works when I insert the code 150001, yes 150001 and not 15001. I couldn't think up a code to turn the light off. The only way to turn off the light is taking a picture with my camera. Maybe there some others with this problem. Try to take a photo to turn your light off.
Patrick, I already covered the correct use of flashlight in Post 10 of this thread. 😊
HTH.
Brilliant. Just installed and it works perfectly. That'll come in handy in the dark mornings.
1 Question. I'm assuming there is nothing running in the background and I only need to deactivate it if i need to use the camera as a camera?...
EDIT - just realised that the light stays on even when you shut the slider....so yes, I do need to deactivate it!
I did follow the thread instruction but my N72 only produces flishing light not a steady light or torch need more help..thanks
