I have recently installed TT5.2 on my N70, I have a problem (as well as the obvious loss of GPS connection) which is that when I go to open my gallery it shows all of the TT images in there including speed camera and all POI images plus the images for the different voices.
How do I fix this as my memory card is incredibly slow to access!
Not sure you can.
It picks up album art images from within the Sounds\Digital folder on the E: drive as well.
It ignores images in the root of the memory card but I don't think Tom Tom will see the POI images if you move them.
Is there any way to put them all in 1 file on the memory card or something?
Put your memory card into your pc and open the map folder where the speed camera images are, right click on each image and click properties, at the bottom of the properties page tick hidden then apply.
Do the above for each camera image and by doing that it they wont show in phones gallery anymore, plus it works for the voice images also.
Or instead of doing each one individually,select all of the images, then right click on one of the selected ones and when you select hidden it will make them all hidden.
