hi everyone... does any one know where i can get a software that enables arabic?? u know.. to send sms in arabic.. thanks alot
Arabic for Nokia N80
My phone is arabic and english with arabic and english keypad aswell. I bought my'n from Dubai
Flash it with language pack (08) this contains full arabic support and allows you to write sms set contacts etc in Arabic you can even turn the whole phone interface into Arabic.
thanks guys for the info... but the problem is i live in the US.. any other ideas??? i did find a couple of softwares that enable arabic.. but they dont work on S60 3rd Edition.. so i was thinking if there is some kind of software that can convert S60 2nd edition softwares into S60 3rd edition softwares.. what do u think guys???
thanks very much for it
Like Jayd said, you can flash it using a specific geographic area code. Use NSS to change your product code to the mid-east region, then update your firmware with NSU. It doesn't matter where you are in the world, it will work.
There are a good number of threads on this subject already, in particular search for anything dealing with 'debranding' and you'll be on the path to having Arabic on your phone in no time.
thx
