Hi All,
I m using N72, there is one problem if anyone help me out, Its not supporting Taxt Msg via Cable or Bluetooth using Nokia PC Suite connectivity software...further more i visited Nokia Suite site and find out tht there r only specific nokia cell phones who support PC txt msaging....anyone help me out that how would I send text msg using PC Suite software?
peeru wrote:Hi All,
YOu should have PC Suite 6.80.22 from www.nokia.com/pcsuite installed and it should work with N72. What type of problems you have ?
manta wrote:YOu should have PC Suite 6.80.22 from www.nokia.com/pcsuite installed and it should work with N72. What type of problems you have ?
Thx for the reply, I have upgraded from PC Suite 6.80.21 to 6.80.22 but the same problem accure.When I right Click on Msg in taskbar Nokia PC Suite it open a window which address is "nokia phone browser\Nokia 72\Messages\inbox" and one additional small window open that says "the operation could not be complete".All other applications works perfect.
Uninstall all PCSuite and clean the PC registry, with all entries related with PCSuite. Reboot and, install again the last version.
