:frown: hi. please help. i recently bought a nokia 3250. its ok. however, i make most calls from car bluetooth device and with this nokia i cant remove original voice tags and put in my own. :turtle: :turtle: :banghead:
Nokia 3250 - Ask any questions and I'll / we'll (try) to answer.
Hello,
My name is Laytonia and last night while playing around with my nokia 3250 I accidently turned on the headset answering option and because of this I cannot talk on my phone unless I turn on loudspeaker. I really want to be able to answer my phone with more privacy. Can you help me? I can see the headphones icon on the upper right hand corner of my screen.
LS
How can i install 3250 theme?
I just bought a brand new Nokia 3250, its a great phone, but i'm
a bit angry a those damn Voice-tags that the phone automaticly
generates out of your contacts name.
I dont want everyone to know who it is everytime someone calls me.
How can i deactivate this function???
PLZ HELP 😞
email me at: [email][email protected][/email]
Menu - Tools - Profiles - The profile - Options - Personalize - Said name from call - No (the terms may be different, because I made a translate from my system language).
Few problems:
*how do i delete ALL messages and Contacts?
*Memory card is not always recognised, i have to take it out and put it in 4 da fone to recognise.
*Music doesnt always play
rajy wrote:Few problems:
*how do i delete ALL messages and Contacts?Menu - Messages - Inbox (or other) - Mark / Unmark - Mark all - C key - yes
Menu - Contacts - Options - Mark / Unmark - Mark all - C Key - yes*Memory card is not always recognised, i have to take it out and put it in 4 da fone to recognise.
Same problem on N80 and N73. Seems a card related problem, because some others said, that with Sandisk Ultra cards, there is no problem. Test...
Firmware problem:con? Check witch FW version do you have on it.
hello
i have problem when i try to install some application on mobile or bluetooth some music from friend it will have massage "not enough space" in memory card although it has a lot of space how to fix it?
thank
Is not card memory, but phone memory. Copy the files you want install to the card, and then install it with Y-Browser or the file explorer that came with 3250.
Oi buddies..can anyone tell me how to uninstall applications on my nokia 3250
On S60v3 is easy... Put the cursor on the application, press C key, answer Yes.
How can I increase video resolution on 3250?😎
It records 176x144 @ 15 fps...
If it can be as on the for example on N70 (352x288, CIF)?
Is there any additional application such as Eti camcoder for SymbOS 6 & 7?:icon4:
Where to find?:con?
thanks a lot nj7!have a nice day
hi everyone i just bought this beautiful phonebut when i try to switch on camera the phone says me "General: feature not supported" and come back to menu!!
what i must do??please help me i'm desperated....
Do a phone format: *#7370#. Try again!
please help me my 3250 doesnt install j2me&java apps it goes to the before end bar and then stop to say cannot install this program please reply to me at the very quick time :redface:
i did *#7370# but is the same thing...feaure not supported...HELP ME
hey i have only one problem and thats wen i txt msg it takes forever i mean forever to go through. can you tell me how to fix that?? thanks
oi ! how can i play video files that are in formats other than 3gp on my 3250?
il_messia wrote:i did *#7370# but is the same thing...feaure not supported...HELP ME
If that still don�t work even with a phone format, only a Nokia Service can help you.
hi guys, wassup, just wana ask, you see im trying to download repligo for some purpose, religious perpuso where u can read holy hymn, so the thing is i cant download the repligo file to my 3250 phone.Is there any other software where i can read em on my phone? the fonts are like sanskrit , so dont mind heling me out..thanks:>
how to remove operator logo for nokia 3250? detaill.............plz
Hi everyone! Can somebody help me with my N3250..how do u reprogram this kind of phone...?
Reprogram:con? Format? *#7370#. Another software, you can�t!
Sorry for the double post, didn't notice this thread until I had posted the other one...
My problem is that I would like to find a way to "replace" the default, pre-installed musicplayer with anoter one. I have LCG Jukebox and love it. I would reeealy like it if I could make that one start when I twist the bottom of the 3250.
Is there any way that this is possible? :con?
Install Oggplayer, free software. You can find it on software section of this site.
Hi. :con? Do you know if the nokia 3250 is compatible with SanDisk 2GB Micro SD Card?
preventerwind wrote:Hi. :con? Do you know if the nokia 3250 is compatible with SanDisk 2GB Micro SD Card?
There is a thread about that. Search a little. My advice, is, if possible, try before buy.
nj7 wrote:Install Oggplayer, free software. You can find it on software section of this site.
The main point in my queiry is that I want to still be able to use the twist funktion (and the dedicated play/stop etc buttons). I have LCG player, wich I like. The dedicated buttons work, but I can't figure out how to make it start when I twist the bottom.Does oggplayer really solve that?
Well, I'll check ouy oggplayer and see if it helps. Thanks for the answer.
i'm trying to flash my nokia 3250, from v 4.14 to v 3.23
when i updated my firmeware, i lost arabic language!
my phone is certified ME edition, i'm supoose to get arabic with NSU
ofcourse no luck with Nokia, support team! i'll have to do it my self
i looked here, and i followed the steps on how to install Phoenix, and i did succesfully, but with one problems, when i scan my phone, i only get
-Phone Version: which is v 4.14 10-10-06 RM-38
-IMEI: XXXXXXXXXXXX :-P
and thats it!
no information being populated?
can some one help.
things that i have and installed:-
1- phoenix_service_sw_2006_12_5_136.exe
2-55667793_Diego_3_06.msi
3-Nokia_Connectivity_Cable_Driver_6_80_5_1_eng_uk.msi
4-3250_RM38_3.23_15-05-06
Any Ideas..........,
