N80 WiFi not coonecting to HotSpot T-Mobile
3 replies · 2,561 views · Started 27 July 2006
I have recently bought 1 month access to t-mobile hotspots. I can connect to internet from the laptop but not getting connected from my n80, error message comes no gateway reply. has anyone come across this problem? T-mobile login page not loading.
btopenworld page loads when i try to connect to their hotspot but not t-mobile.
HELP!
khedara wrote:I have recently bought 1 month access to t-mobile hotspots. I can connect to internet from the laptop but not getting connected from my n80, error message comes no gateway reply. has anyone come across this problem? T-mobile login page not loading.
HELP!
Have you managed to solve this issue?
I get the same message "no reply from gateway" when connection to my open/none access point at home. Are you able to connect to any other access point?
This phone is supposed to support WPA/2 wep & 802.1x auth but I can't get any to work at all.
I can't see a setting to configure IP & GW addressing.
Can anyone help us.
This afternoon I think i figoured out why its not connecting, but not 100% sure, cos n80 is 802.11g and the wifi networks t-mobile using are 802.11b so maybe thats the reason why i can't connect to t-mobile wifi. I can connect to my home network no problem that is with 802.11b/g.
check this on your home router to see if its 802.11g and b.
see if this helps- Conn. mgr. > Availab. WLAN > option> difine access point> advance settings... from there you can configour ip settings
