help calnt instal anything on my n70
2 replies · 1,695 views · Started 27 July 2006
i am trying to install aplications and themes on my n70 but when i try to install my phone says instalation security error unable to install i use the nokia pc suite installer and that dosent work what can i do:con? :con?
If You use the correct version software, then go to N70 and do like that: Menu - Tools - Aplication Gestion - Options - Defenitions - Install Software (Yes) and Check On-lin Certifyd (No).
Sometimes, your network disables the software installation of your phone through your PC suite. It only allows installation through OTA, meaning from their company, which they think only signed and safe software enters your phone system.
