hi
i am using nokia 3250 n i just now formatted my memory card n after formatting i can harldy install files but some files can be install but some can not be install
i was not facing this problem before, before i could install each and every file of nokia 3250
why i am facing this problem can any one help me???
plz help me
if you format it using n3250 mmemory card menu , try to format your memory card by computer ( connecting as DATA TRANSFER ) and then use your n3250 .
i think this might work :icon14:
thanks 4 d suggestion but its not working can u give me another suggestion 4 d same problem
