If there are any users that are using Optus as there provider could you please help me out with some settings that i feel optus stuffed up when i purchased my phone. thanx 😊
Any 7650 users on Optus Australia?
im not on optus, but i can help u with your phone settings, im in australia
tell me what ur problem is?
which setting do u want ???
i hav all setting for operators in australia
😃 It's installed in my phone 😃
nightlfy can u give me all the settings for all the operators, as when i formatted my phone i lost all the settings, i can only get vodaphone 😞 and i need telstra or else i can't check my bigpond account.
would greatly appreciate it.
Connection name telsta GPRS
Data Bearer GPRS
Access point name telstra.wap.mnc001.mcc505.gprs
User name
prompt pass
pass
authen
gateawy 10.1.1.150
homepage Wap.telstra.com/wap
conn security on
session permanent
Connection name telsta.internet
Data Bearer GPRS
Access point name telstra.internet
User name
prompt pass
pass
authen normal
gateawy 0.0.0.0
Connection name telsta.MMS
Data Bearer GPRS
User name
prompt pass
pass
authen
gateawy 10.1.1.155
homepage mmsc.telstra.com:8002
conn security off
session permanent
Connection name telsta.GSM
Data Bearer GMS data
Dial up no +61418707649
User name
prompt pass
pass
authen secure
gateawy 10.1.1.150
data call type ISDN v 1.10
max data speed 9600
conn security on
session permanent
do u need the other operators ??? :cry: :cry:
i;m too lazy to type even with copy n paste 😃 😃
but if u really want it
it;s ok 😃 😃 😃 😃
no, thats enuff, thanks alot, i really appreciate it 😊 😊 😊
[quote="555"]no, thats enuff, thanks alot, i really appreciate it 😊 😊 😊[/quote]
:angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel:
Connection name Yes Info wap
Data Bearer GSM data
dial up no 638
User name none
prompt pass no
pass
authen Normal
gateawy 202.139.83.152
homepage networker.optus.net.au/wap/index.wml
data call type isdn v. 110
max data speed 9600
conn security off
session permanent
Connection name yesinfo internet
Data Bearer GPRS
Access point name internet
User name
prompt pass
pass
authen normal
gateawy 0.0.0.0
Connection name Yes info wap plus
Data Bearer GPRS
Access point name wap.optus.net.au
User name
prompt pass
pass
authen normal
homepage Networker.optus.net.au/wap/index.wml
conn security off
session permanent
G'day Nightfly,
It would be great if you posted Optus info as well as with 555 I think Optus stuffed up mine .
Got a bill for $255 for GPRS incorrectly charged for WAP
Surely I don't need Telsta settings to access Bigpong as I was able to access my emails but had dramas sending emails b4 Telstra NSC updated my phone &removed my settings .
Many Thankz
[quote="Rotten Ronnie"]G'day Nightfly,
Many Thankz[/quote]
There u go m8
wow $255 i'll runaway 😃 😃
do u need the MMS one ???
thanx agian, i will use this info to help out bobby
Yes Please Nightfly
Thanx all for you help, all is now working well. Although I just found out that optus charges 3.3c per kb!!! :-? so even though its working i wont be using it much... it just cost me like $11 to a 360kb .wav file.
heheh yeah gprs is expensive that is y i don't use it, i'd rather use my wap over gsm to check emails as i get $100 worth of free calls per month.
bobby, i suggest u invest in a bluetooth adapter as i have
http://www.busybits.com.au/item/DLI84010
this is the one that i have its very small, works fine and if u have any problems i can help u out.
yes i think most certainly i will be investing in one of them in the future. Once again thanx all for your help 😊
bobby where r u if u r in sydney i can give u a store with a nice price for bt adapter
Im in Brisbane nightfly but if you know of anywhere i could pick one up here that would be great thanx 😊
ough
in Brisbane i dunno where to buy BT in Brisbane never been there 😃
"OOT"
but i know there is a big gameshop over there this is the website www.burn.com.au
hav u been there ???
No I havnt been there yet but i will check it out and let you know what its like 😊 Im sure I won't have too much trouble finding bluetooth here ..... hopefully
hi nightfly, could u please give me the Optus MMS Settings for Nokia7650?
