Hi Folks
this is my first thread so please bere with me, i have 2 issues at present:
1. having dropped my fone in a p1ssed up state last weekend, i have stractched the hell out of it, decided to buy a new case off ebay for �6, are these any good??? the thing is now the fone doesnt click into place when shut, like it does when opened, im sure it used to, but i'm not 100% can anyone please confirm??
decent site for instructions for taking n80 apart
http://web.mac.com/the_reamer/iWeb/freestyle/Message%20Board/9C04C0E7-357E-4648-9585-42BDAEF72CB4.html
2. i have my fone with orange and aleady have a (what was wanadoo) orange live box, but i have spent hours trying to configure it to my fone, i have tried weps, wpas and macs, has anyone managed this? does anyone have idiot proof guide as how to set this up?? at work we have an un encrypted wlan and i do a search pic up the wlan and bingo, straight on. when i do a search at home i can see my wlan network and about 5 others but they are all encrypted and i am not too sure which codes to use
please help & cheers for reading
Dean
yes, there is a definate click when opening. Right at the end of the slide.
should there be a definite clicck when closing to, i thought it did but i maybe be confusing it with my 6280
cheers
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
have a luk under ur orange live box, ur WEP key may b wrote down on the sticker?
yeah, i have that along with wpa and mac of live box but still cant suss it ot
ok in ur n80 goto conection settings, then access points and create new, CONNECTION NAME: call it what u want, DATA BEARER: wireless LAN, WLAN NETWORK NAME: select search for network and select urs, NETWORK STATUS: public, WLAN NETWORK MODE: depends, most common is infrastructure, WLAN SECURITY MODE: try WEP, then go into WLAN SECURITY SETTINGS, WEP KEY IN USE: #1, AUTHENTICATION TYPE: open, go into WEP KEY SETTINGS, WEP ENCRYPTION: try 64 bits first, WEP KEY FORMAT: try hexadecimal first, WEP KEY: ur wep key found under roputer! try that, if it still dnt work play around with those WEP ENCRYPTION and WEP KEY FORMAT settings!
biggzy
cheers for your help so far mate, thought i nearly had it, at the 10th attempt managed to get it to accept the wep, (what a bitch trying to enter that!!) now when i try and log on the the internet via wlan, i choose wanadoo, the it asks for a 'Pre-shared key for WLAN:'
any ideas what i need to do next, so close but still so far.....
