Hi, I just recently purchased a Nokia N8. Nice phone but I got a problem, it wont play real player video files, when i try to open a real player file, it says "unable to play sound or video, trying to play file partially" and then it plays the sound but with no picture, how can I get the picture?
Whats strange is one of the rm files has picture and sound but the others dont, please help.
Cheers.
possibly could be a codec issue. The file you want to play might be compatible with Real Player but could of been encoded with a specific codec which isnt on your phone.
unfortunatly i dont know of any codecs for the N80. I dont have the same issue as you though. All my files seem to be working perfectly
What video and audio file formats are supported by many Nokia phone models, you can find out here: http://forum.nokia.com/video
Thanks for the link.
My files are the same so far; vnd.rn-realmedia. One file works OK but the others dont have apicture even though they're the same format.
