Hello everyone, there is a problem i am facing.... i found and installed some themes into my N80 handset, and after awhile i wish to delete some which i doesn't want anymore, but i couldn't find the option for deleting themes... Please help..... thanks...
deleting themes in N80?? Pls Help
navigate the menus, TOOLS -> APP MANAGER
then scroll to select the theme or application
then press OPTIONS -> REMOVE
hey there, thanks for the reply... appreciate it.... however, i manage to only see a few of the installed themes but not all of them, why is this so??? could anyone solve my query?
You can delete the themes You have installed. You can�t delete ROM themes, that belong to the phone.
ya, i know what u means, but it was like i installed about 6 themes, but i could only see 2 themes in the app. manager.... what happen? thanks for all the replies....
All those themes are S60 v3 compatible?
i am afraid not all is v3 compatible.... which means i could only delete those which is meant for v3?
Only that ones have been installed... the others, do a search in apllication manger, if you see the names.
ya, i did tried to look for the rest of the themes, but my N80 app manager is empty, and i was wondering why the themes isn't in any of the folder in our file manager?
The apllication manager that cames with the phone don�t list system files. Use another one.
which one do you mean?? i still cant figure out how.... thanks....
Get SysExplorer for your phone and find them with that
Or Y_Browser - is free!
i downloaded sysexplorer, but i couldn't find the themes?? where is it located at?
