Try and Buy address
3 replies · 3,415 views · Started 30 July 2006
I used to have the "try and buy" shortcut in the multimedia forlder before I upgrade the phone... I can donwload and try few software at the "try and buy" site. However, after upgrading my firware, it was no longer there... And I can't seem to find the site... Anybody who still have the shortcut? Can you tell me what the site address is? You can see it in the page information on your phone browser. Thanks!
I never paid attention to Try and Buy before, bt just noticed that the link is actually stored inside your phone. When I looked at the main site's address, it shows something like "file://localhost/d:document/try and buy/..."
You can look for this link through file manager in your computer or phone.
Did you take a backup right Before upgrading the firmawre? If you backed-up everything, you should be able to see that after restoration.
Most, if not all software, can be found in Nokia Site - Market Store, with option for try and buy.
kylom wrote:For Sony Ericsson M600i?? That would be surprising :con? . You should rather try http://www.sonyericsson.com/applicationshop.
Regards,
Yes, forgive me! :redface: You are right! Is the problem of doing a lot of things at same time. No, for a M600i, is NOT in the Nokia Site. Thanks for the correction:icon14:
