BAD Snails
7 replies · 2,122 views · Started 02 December 2002
I am having gret difficulites removing the demo of snails.
I can se a remove option and when i use seleq and try and remove it it asks if i wish to remove the system file as well.
Has anyone else managed?
The new version of seleq i have yet to purchase anyone found bad bugs or are we generally happy bunnies?
It happend to me once i could'nt remove a certian program, i just installed it, then i reinstalled it succefully.
y don't u just remove it from the manager (thats what i did), y are you using seleq to remove it?
I normally remove my apps via manager but thhis app does not show up anywhere apart from the C:\system\apps and then that's where i get the message asking if i wished to delete the system files.
Seleq is the app i use for my file management the demo runs out today so i am going to have to purchase some file management software what do you guys use?
[quote="Robbie"]I normally remove my apps via manager but thhis app does not show up anywhere apart from the C:\system\apps and then that's where i get the message asking if i wished to delete the system files.
Seleq is the app i use for my file management the demo runs out today so i am going to have to purchase some file management software what do you guys use?[/quote]
i;m using seleq but i bought it when it was $12 special price
Seleq -- lots of features
handy file -- simple n small amount of kb
filemanager -- same with handy file
[quote="xzibit"]it should show up in the manager as "minimal application" if thats any help 😃[/quote]
great photo bro!!! :P
