Hello! I'm writing here, because problems with my mobile phone (Nokia 6680) started being too big... I'm quite an new user so some of those problems might be simple for you. I hope some of you could help me and tell what to do to solve them...
Here we go:
1.I cannot add users to my groups. I mean, some users I can, some not and I have no idea why. When I try to add an user, I tick the box near it and press "ok". After it, the group list closes and I can see my main window (no processes working, after pressing and holding that left-down button)
2.I cannot record videos. When I try to do so, it gives an error that the feature is not supported. When I got a mobile phone for the first time, I started clearing applications I thought that were unneccessary for me... probably, I've deleted one that was providing this function...
3.The phone crashes many times (too many). E.g. when I'm writing some notes, after a while I realise that the program crashes. I can preview the "task menu" and close the notepad but it's impossible to enter the application menu again (no response). It's similarly when I do anything other (it's not Notes fault), there is no clear reason when it happens.
4.I cannot connect my phone to the PC (no more). I don't know if I've deleted any important program to do so, but the program (Nokia Suite) doesn't see the connected phone. When I press "synchronise" in Connectivity/Sync/Nokia PC Suite I got message that memory is full. I reinstalled the drivers and program on my PC twice.
5.It's not a problem but I just wanted to know - how can I use a new memory card without restarting the phone? It's no problem to take the card out but when I put it back, the phone doesn't recognise it automatically.
I would like just to add that I have got FExplorer installed so if I need to do sth with it, it's no problem.
Btw, I've heard that there are new firmwares for my phone. How can I install them? Should I ? My system version:
V 2.04.15
04-03-05
RM-36
I would be really grateful for all help and information.
Greetings,
Theriel
