I have using the Holux 236 GPS with the Nokia 6620 without a problem, they are linked once the bluetooth connection is up.
But I recently try to hook up the Holux with 6682, the phone shows it is connected with the GPS unit. However, the TomTom Mobile software keeps saying "No GPS Signal" !!! First, I thought it is the GPS unit problem. But as soon as I turn on the 6620, TomTom in the 6620 has picked up the GPS signal. (Note: Both the 6620 & 6682 have been installed the same TomTom Softwares)
I have tried turning off both units and reboot, pair up both units many times, but still the same
Can someone please advise if this is problem with the version of TomTom I am using ? If so, can you please give the correct version for the 6682 ? Thanks a lot.
