Is there a way to create and edit new text documents on the N80? Or do you need some kind of 3rd party software for this?
Creating text documents
Notes are text documents if you send them via Bluetooth. Otherwise you'll need to look at Office Suite.
You need third party software and the one I had pre-installed on the phone was Quickoffice that allows you to view documents. There is also QuickOffice Premier that allows you to create and edit documents but unfortunately it�s not available till 1 Sept 06.
I've enclosed the link to their website for further information - http://www.quickoffice.com/s60/
thers an app caled office suite, that lets u edit etc
Biggzy wrote:thers an app caled office suite, that lets u edit etc
The details on Office Suite can be found at the attached link - http://www.allaboutsymbian.com/reviews/item/OfficeSuite_S60.php
Thanks for the info!
