hi guyes, i would just like to know if there will ever be a sat nav for the N80.
with the recent problems with route 66 and Navicore recently saying that the n80 does not work with their symbian 3os will any one bring one out. What about tom tom will they even bother.
Feeling a bit down as i feel i have bought the wrong mobile and i am still lugging around my 6630 to use tomtom mobile 5!
Any ideas on a good sat nav Please helP???
Both Wayfinder and Nokia are said to work on the problem.
Wayfinder works on my N80 (firmware v3.0614.03 11/04/2006 RM92) using a Holux GPSlim 236 without issue, as does Nav4All.
TazUk wrote:Wayfinder works on my N80 (firmware v3.0614.03 11/04/2006 RM92) using a Holux GPSlim 236 without issue, as does Nav4All.
Yes, it probably would. From my testing with ViewRanger, it seems the bluetooth connection issue was introduced in the last firmware upgrade (.617).
For others, like other kind of programs, You should wait a little more.
Yeh nav 4 all is poo what is wayfinder like can any one show me ne pics
Hey can any one tell me how to get a copy for way finder cheap and if so will it def work on n80 cos the web sits say it doesn't
GAZ5355 wrote:Hey can any one tell me how to get a copy for way finder cheap and if so will it def work on n80 cos the web sits say it doesn't
It worked on my N80 (note firmware version) as per my post above. Best bet is to download the trial and give it a whirl yourself - that's what I did. I'm just waiting on my GPRS bill before I make my final decision.
Cheap? 99 Euros for UK & Ireland works out at about �67 at the current exchange rates. If you're talking about cracks they aren't discussed on this site and I'd think it unlikely anyway; as an off-board system they can check activation codes each time you calculate the route.
