hi all
okay, I didn't buy E70 yet and I am still hesitating between Nokia E70 and imate SP5. the major advantage in imate from my viewpoint is the activesync application. I can use it to sync my emails, files, contacts, calendar,.. etct. is it possible in NOkia E70 to do the same? even using third party application? and which app?
ahmedwk wrote:hi allokay, I didn't buy E70 yet and I am still hesitating between Nokia E70 and imate SP5. the major advantage in imate from my viewpoint is the activesync application. I can use it to sync my emails, files, contacts, calendar,.. etct. is it possible in NOkia E70 to do the same? even using third party application? and which app?
E70 can sync with MS outlook :deal:
But the Nokia PC Suite cannot sync email with Outlook with an E70 (only with 9500, 9300, 9300i).
However, you could try direct over-the-air sync with Exchange, instead (if your IT department supports it).
okay, forget about the email sync.. what about files and folders sync? is it possible?
what about software that sync email?
this mobile is for me and not for business so I can't use it with MS exchange
