I should port some code written for Sony-Ericsson p800 to Nokia 9210. Where can I find some documents to compare the libraries and find the matching functions between the two models?
Silvia
how to porting uiq 70 to s60 for nokia 9210
Your subject says "uiq 70". There is no "uiq 70". The Sony Ericsson P800 is based on UIQ 2.0 on top of Symbian OS (Operating System) 7.0.
You mention the Nokia 9210. It is a Symbian OS 6.1 device using Series 80 1.0, but you are asking on a Series 60/S60 forum for the N92 and N93 models.
In any case, search http://www.symbian.com/developer and http://forum.nokia.com for various porting whitepapers. In addition to that, read the SDK docs.
If you need further help, you might want to use a developer discussion forum, instead. In addition, you should be very clear which device the original code is written for, and what is the target device (without mixing and confusing OS versions with different platforms and their versions).
And it'd be even better, if you tried the porting first yourself, and then come back with actual problems or issues you can't solve (with code snippets or compilation errors that you can't overcome or figure out the reason for, for example) based on the available documentation.
