What is the correct procedure of running two emulators using CodeWarrior at the same time. I copied the folder structure to a separate location, allocated different IP addressses and MAC addresses to the two and ran the two emulators using the epoc.exes in the different folders. They run at the same time, but seem to be using some common resources since both emulators can not open sockets to a remote server (not in an emulator) at the same time. Any ideas on what is going on?
Regards.
Daya
