Wayfinder for N80
4 replies · 1,875 views · Started 01 August 2006
Hey can any one tell me how to get a copy for way finder cheap and if so will it def work on n80 cos the web sites say it doesn't
cheers
GAZ5355 wrote:Hey can any one tell me how to get a copy for way finder cheap and if so will it def work on n80 cos the web sites say it doesn't
What sort of dumb question is this? Wayfinder is a commercial program with a set price. No one here will advocate rip-off copies of any commercial program at knock down prices from illegitimate sources. And if the developer acknowledges compatibility issues, chances are, there will be compatibilitiy issues.
well ive all ready seen about 3 differnt prices on 3 different websites dumb ass and i wasnt on about ripoff copys!!
Oh good, a flame war. 😉
If you check the post, I wasn't referring to you as dumb but rather the question, which had been worded rather ambiguously to suggest the search of a copy of the program on the cheap. However, if you want to make it personal, I would suggest that next time, (a) don't be so puerile and (b) be more specific with your questioning. That way you might elicit the answer you seek.
And in light of the new information you supplied, sorry no, I don't know of anywhere you can buy a legitimate copy of the program more cheaply than from the developer.
Someone in this Forum said that Wayfinder work on N80! But you can download a 5 day trial from wayfinder site and test for your self.
